17 years agousing a ram megafunction
I am emulating a microprocessor on DE1 development kit. i heard that need to use ram megafunction to generate the ram only can simulate the microprocessor on DE1. so how can i create the ram using th...
17 years ago --- Quote Start --- Basically, I tried to focus on the original question. Further suggestions may be helpful, of course. I think, however, you should also give some explanation for what you regard as best practise. --- Quote End --- Agreed. Sorry about that. Thanks for clearing up my post. Just a few comments below. --- Quote Start --- std_logic_unsigned may be regarded as bad practise. Personally, I dislike it too. But it simply introduces a Verilog-like behaviour in VHDL and may be appropriate for some simple applications. Regarding std_logic_arith, did you notice that all (or most) Altera VHDL IP is using it? --- Quote End --- I do see Altera's IP using it, and I cringe every time I see them used. On a side note, I don't like how all of their IP ports which are clearly fed with signed or unsigned data don't expose this datatype. --- Quote Start --- It's fully legal VHDL code anyway. In an edge sensitive process, a sensitivity doesn't change the behaviour, neither in synthesis nor simulation. (Personally, I would use process(clock) at least to improve readbility and reserve wait until for simulation timing.) --- Quote End --- Agreed and understandable. VHDL is extremely versatile, but not necessarily always the easiest to read - so maintaining a clear intent is important when writing code.
