17 years agousing a ram megafunction
I am emulating a microprocessor on DE1 development kit. i heard that need to use ram megafunction to generate the ram only can simulate the microprocessor on DE1. so how can i create the ram using th...
17 years ago --- Quote Start --- While Quartus may infer a RAM from this code, it's not using best practices. --- Quote End --- It actually does. Basically, I tried to focus on the original question. Further suggestions may be helpful, of course. I think, however, you should also give some explanation for what you regard as best practise. --- Quote Start --- First, you should be using ieee.numeric_std.all instead of std_logic_arith, and std_logic_unsigned. --- Quote End --- std_logic_unsigned may be regarded as bad practise. Personally, I dislike it too. But it simply introduces a Verilog-like behaviour in VHDL and may be appropriate for some simple applications. Regarding std_logic_arith, did you notice that all (or most) Altera VHDL IP is using it? --- Quote Start --- Second, your memory access process should have a sensitivity list and look something like this. --- Quote End --- It's fully legal VHDL code anyway. In an edge sensitive process, a sensitivity doesn't change the behaviour, neither in synthesis nor simulation. (Personally, I would use process(clock) at least to improve readbility and reserve wait until for simulation timing.) As another comment: after 1 ns is valid in simulation only and ignored in synthesis. And the rw / memsave logic seems dubious to me, but may serve a purpose anyway.
