Using 10CL006 programming file on the 10CL010
"There is a post suggesting that it might be ok to program the 10CL025 with the 10CL016 rbf programming file here:"
--- That post does NOT say it is ok to use the same binary programming file for the two different devices. Read it again.
"Also, we did a comparison between the rbf files of the 10CL006 and 10CL010 and we did find differences for the same design"
--- Different cell count and physical layout, different cell assignment in the device.
Each device, even with the exact same top level design, requires a device specific compilation.
If you build a board with either of the two devices, read the JTAG device ID first and then program with the appropriate binary file.
The device IDs of the 006 and 010 are the same according to Table 59 in die Device Handbook.
