11 years ago
User Interface to control SRAM (cyclone iii starter kit board)
Dear Altera user,
I'm using an altera board Cyclone iii start kit (with external Sram and Dram)
I explain here the way I'am using it, but I'm looking for a better solution.
The problem concerns the load/dump of the external sram.
I have a design which needs to read the external Sram and write into it.
I need to load the Sram with raw data, process the data with my design and then dump the memory to get the result.
For loading/dumping the Sram, I used the Board Control Panel application.
1) Start the Board Panel : load a file into the memory
2) launch the Quartus programmer to put the Design in the FPGA
3) Start the processing
4) When it finishes, I reconfigure the Board with default *.sof (in order to get control panel working)
5) Start the Board Panel : dump the Sram contents into a file
Question1: How can I write an application (graphical or through console) to do the same thing without
reconfiguring the FPGA, I want to configure the FPGA once with my design and be able to load/dump memory
as often as I want.
Thanks for your help
    --- Quote Start ---
    hello sriram7,
    Here is the way how i have implemented the sram controller for the ciii starter kit, schematic and timing relation ship, hope that can help you.
    --- Quote End ---
    hi, could you publish your code please?
    or send it to me yonatanhanann@gmail.com
    i'm having problems with it to.
