11 years agoUser Interface to control SRAM (cyclone iii starter kit board)
Dear Altera user,
I'm using an altera board Cyclone iii start kit (with external Sram and Dram) I explain here the way I'am using it, but I'm looking for a better solution. The problem concerns the load/dump of the external sram. I have a design which needs to read the external Sram and write into it. I need to load the Sram with raw data, process the data with my design and then dump the memory to get the result. For loading/dumping the Sram, I used the Board Control Panel application. 1) Start the Board Panel : load a file into the memory 2) launch the Quartus programmer to put the Design in the FPGA 3) Start the processing 4) When it finishes, I reconfigure the Board with default *.sof (in order to get control panel working) 5) Start the Board Panel : dump the Sram contents into a file Question1: How can I write an application (graphical or through console) to do the same thing without reconfiguring the FPGA, I want to configure the FPGA once with my design and be able to load/dump memory as often as I want. Thanks for your help
