16 years agoUse PLL between the dedicated clock input pin and output pin.
I am using the cyclone II series, and my global clock(32M,input_clk) is inputed by a dedicated clock input pin(clk0). Now I need a clock which is 4MHz divided by input_clk, and output it to a ...
16 years ago --- Quote Start --- It's easy in this case, because Cyclone II has no real LVDS driver. You must use a resistor network at the output to achieve a correct LVDS level anyway. For a slow 4 MHz output, it's no problem to use a pseudo-differential output by connecting an inverter for the inverted pin. This is the only way to get a differential output at the dedicated clock output pins without driving it from the PLL. --- Quote End --- To FvM: Actually,I don't need a LVDS clock output, but my input clock already use the LVDS standand, and the output pin was assigned in the same I/O bank, so I have to set the output pin with LVDS standand. In this situation, what can I do?
