16 years agoUse PLL between the dedicated clock input pin and output pin.
I am using the cyclone II series, and my global clock(32M,input_clk) is inputed by a dedicated clock input pin(clk0). Now I need a clock which is 4MHz divided by input_clk, and output it to a ...
16 years ago --- Quote Start --- The restriction is in the VCO frequency range and maximum divider count of 32. You have to use a post divider in logic. If a specific output timing is required for the output, you can supply the post divider with a phase shifted clock and adjust for the extra delay. The slightly increased jitter and timing inaccuracy shouldn't matter that much at 4 MHz. --- Quote End --- I forgot to mention that I use the LVDS I/O standand on both the input clock and output clock. When I put a divider between the PLL and output pin, an error happened: Pin "clkout" with LVDS I/O standard must be driven by the external clock output of an enhanced PLL". What's the solution? I totally have no idea.
