Use cyclone 10 GX transceiver as 1-bit ADC
As I understand it, you have some inquiries related to our C10GX RX CDR in lock-to-ref mode. For your information, when the CDR is manually forced to lock-to-ref mode, the CDR is not tracking the incoming data. We cannot guarantee if the data will still be sampled correctly. As I understand it, I have come across cases where the incoming data rate is lower than the supported range of CDR, the application will put CDR to lock-to-ref mode and recover the data using custom logic.
Therefore, specific to your target implementation, I am not sure if the CDR is able to sample the data correctly since the CDR is not intended to sample data at lock-to-ref mode. If you have a C10GX hardware available, you might want to perform some tests to check out if your target implementation could work. Sorry for the inconvenience.
Chee Pin
- KeeganJ5 years ago
Thanks for your response.
Basically it is not serial digital data, that is the reason for my question. It is not the common usage of transmitting/receiving serial data.
It is a totally asynchronous stream of pulses, not synchronous to any clock. So I do not want to lock the CDR to the data... I just need to disable CDR completely and over-sample the input continuously at 10 GHz.
Is it possible to operate the receiver this way? My assumption is it requires the "lock to ref" mode, but I especially want to make sure the receiver will provide data output to the fabric in this mode. Also I assume the PCS should be bypassed with PCS-direct mode.
