16 years agousb transfer for ISP1362 on DE2 board
hi everyone:),
I'm trying to modify the firmware coding for DE2_NIOS_DEVICE_LEDI from DE2_demonstrations. But I had problem to modify the coding to send more than 8 byte data per block. I had modify the coding from ISR.c void Isr_Ep01Done(void) ...(got coding here) Hal4D13_ReadEndpoint(EPINDEX4EP01,(data + offset), 16); offset += 16; c = Hal4D13_GetEndpointStatusWInteruptClear(EPINDEX4EP01); ... Hal4D13_WriteEndpoint(EPINDEX4EP02, data, 16); Hal4D13_GetEndpointStatusWInteruptClear(EPINDEX4EP02); printf("\n"); ... void Isr_Ep02Done(void) { unsignedchar bbuf[16]; int i = 0; Hal4D13_GetEndpointStatusWInteruptClear(EPINDEX4EP02); Hal4D13_ReadEndpoint(EPINDEX4EP02,&bbuf, 16); if( sendCount < length) { Hal4D13_WriteEndpoint(EPINDEX4EP02, data + sendCount, 16); Hal4D13_GetEndpointStatusWInteruptClear(EPINDEX4EP02); sendCount += 16; ... and also had modify the coding from MAINLOOP.c void config_endpoint(void) { ... /*port1 is OUT*/ Hal4D13_SetEndpointConfig( D13REG_EPCNFG_FIFO_EN|D13REG_EPCNFG_NONISOSZ_16,EPINDEX4EP01 ); /*port2 is IN*/ Hal4D13_SetEndpointConfig( D13REG_EPCNFG_FIFO_EN|D13REG_EPCNFG_IN_EN| D13REG_EPCNFG_NONISOSZ_16,EPINDEX4EP02 ); but still, i can't get it function correctly... Can anyone help me??:confused: I'm new in these, please help me... THanks~~~~ summerNo RepliesBe the first to reply
