10 years agousb interfacing
hi everyone,
i am new to fpga. but, i know how to prepare verilog file in quartus2 software. i want use the usb port in altera de2 board for tranfering ang receiving data from pc. but, i don't know exactly what to do. please help me. thank you.12 Replies
Having your computer detect your fpga as a USB device directly is much too complicated for a beginner.
Use a serial port. Your dev board might already have a serial to USB converter on it. Some boards have a serial connector. For this you will need an external serial to USB cable. If you are using a board with neither, consult with someone about finding c converter that won't damage your board when you connect it to gpio pins. This might be a level shifter followed by an serial to USB converter. - Altera_Forum
What is your system and what are you planning to do with it?
You can write the controller yourself or you can find IP of someone who has done this for you. Alternatively you could use a softcore to handle the control
