10 years agousb interfacing
hi everyone, i am new to fpga. but, i know how to prepare verilog file in quartus2 software. i want use the usb port in altera de2 board for tranfering ang receiving data from pc. but, i don't...
10 years agoHaving your computer detect your fpga as a USB device directly is much too complicated for a beginner.
Use a serial port. Your dev board might already have a serial to USB converter on it. Some boards have a serial connector. For this you will need an external serial to USB cable. If you are using a board with neither, consult with someone about finding c converter that won't damage your board when you connect it to gpio pins. This might be a level shifter followed by an serial to USB converter.
