11 years agousb connection problem
PC not detecting altera c3 fpga board when connected to usb port. before some time it was working fine..i also performed led blinking..but suddenly when i switch on today the kit., the leds start bli...
11 years agoDid someone used your board while you are gone?
Well I would normally try to check all button and switches to make sure there are either in the default settings or atleast my settings. Also try restarting my PC, for some reason the programmer will sometimes not be able to detect my usb jtag if I do not restart my PC. If you can detect ur USB and not your device... then try with other board if you have any.
