14 years agoUSB Blaster VCC
Hello :) I'd like a quick confirmation about the USB Blaster. I'm implementing my design on a PCB, and I've to make a connector to programm my FPGA with the USB Blaster. So I decided to pr...
14 years ago --- Quote Start --- And by the way, do you know if ebay's cheap copy of the USB Blaster are functional? --- Quote End --- According to the link: "The mini USB Blaster is another variation of original official altera USB-Blaster. It is based on Cy7C68013 MCU, which use firmware to emulate the FT232BL protocol and drivers and is compatible with original USB-Blaster." So this version is based on a similar approach to this: http://fpga4u.epfl.ch/wiki/fx2 based on some reverse engineering performed by Kolja Waschk (kawk) http://ixo-jtag.sourceforge.net/ http://sourceforge.net/apps/mediawiki/urjtag/index.php?title=cable_altera_usb-blaster Ask the UrJTAG list whether they have used this cable. I suspect that it will work fine. Cheers, Dave
