14 years agoUSB Blaster problem: USB <-> serial
Hi guys, Does any one get the same problem when connecting the usb blaster into DE2 board ? It did not recognize the usb blaster anymore. It showed the message "Found...
11 years agoI just received an email asking for the FT245B EEPROM XML image. I'll post it here in case someone else needs it.
Download the .txt file, change the extension to .xml, and use FT_PROG to program your DE2 board (or any other Terasic-based board that uses the FT245B device). Cheers, Dave
