16 years agoUSB Blaster inaccessible
I've just restarted using Quartus after a long (maybe 2 years?) break. I've updated to web edition 9.1sp1. So all my existing projects needed to be converted. I'm now trying to program using a USB Bl...
16 years agoDid you had a look into the device manager ?
when the USB Blaster is connected via USB, it should appear as "Altera USB-Blaster" and does not require to be connected to a target via the 10 pin JTAG connector. also the USB Blaster drivers can be found here C:\altera\91\quartus\drivers please note that 91 is the version you are currently using and could be 91SP1 in your case also you can use the driver from FTDI as well. i had posted these links a couple of days ago in another thread.
