USB Blaster I is working but USB blaster II NOT working? (important)
- 7 years ago
MAX10M08SAU169 can be programmed using USB Blaster II without changing the frequency. Could you please check the details,
1. First close the programmer & update the drivers for USB Blaster II using "1.5. Installing the Intel FPGA Download Cable II Driver on Windows 7/8 Systems" below user guide,
https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/ug/ug_usb_blstr_ii_cable.pdf
2. Check 10 pin header connection : 1.4. Installing the Intel FPGA Download Cable II for Configuration or Programming
3. Refer 1.8. Setting Up the Intel FPGA Download Cable II Hardware with the Quartus Prime Software from manual
4. Eventually Auto Detect -> Change File->"Start" 5.you can refer the 2.8. Changing the TCK Frequency
Vicky
Vicky
- ocan7 years ago
Hi vicky ,
My problem is solved with your idea's.
I tried step step your suggestions so step 4 ; I changed tck frequency from 24M to 6M:
My file is loading succesfully, thank u very much for reply my message.
Regards...
