USB Blaster I is working but USB blaster II NOT working? (important)
- 7 years ago
MAX10M08SAU169 can be programmed using USB Blaster II without changing the frequency. Could you please check the details,
1. First close the programmer & update the drivers for USB Blaster II using "1.5. Installing the Intel FPGA Download Cable II Driver on Windows 7/8 Systems" below user guide,
https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/ug/ug_usb_blstr_ii_cable.pdf
2. Check 10 pin header connection : 1.4. Installing the Intel FPGA Download Cable II for Configuration or Programming
3. Refer 1.8. Setting Up the Intel FPGA Download Cable II Hardware with the Quartus Prime Software from manual
4. Eventually Auto Detect -> Change File->"Start" 5.you can refer the 2.8. Changing the TCK Frequency
Vicky
one difference is the Clock-frequency. As far as I know, the USB-Blaster II uses a higher frequency (to Speed up config time). Depending on the layout (routing) of your PCB, this can cause issues with Signal distortion. There is an Option to reduce the Clock-Frequency for the USB-Blaster II somewhere...
KR, Carlhermann
