12 years ago
USB Blaster EEPROM Program for Cyclone IV Dev Kit
I have accidentally erased the EEPROM on my CycloneIV development kit and now the computer sees the USB Blaster as USB Serial interface. I tried to reprogram by using FTDI - FT prog and usb_blaster_BLASTR01.xml file from the forum. When I tried to program, FTDI program gives two errors.
First one: The current drawn from the USB port must be in the range 0 to 500mAmps.
Second one: The maximum number of characters for the Manufacturer, Product Description and Serial Number is 46.
It seems this XML code worked for DE1 users and I don't understand why it does not work with my board. Here is the XML code that I used:
<?xml version="1.0" encoding="UTF-8" ?>
- (http://www.alteraforum.com/forum/) <FT_EEPROM>
- (http://www.alteraforum.com/forum/) <Chip_Details>
<Type>FT232/245BM</Type>
</Chip_Details>
- (http://www.alteraforum.com/forum/) <USB_Device_Descriptor>
<VID_PID>2</VID_PID>
<idVendor>09FB</idVendor>
<idProduct>6001</idProduct>
<bcdUSB>USB 1.1</bcdUSB>
</USB_Device_Descriptor>
- (http://www.alteraforum.com/forum/) <USB_Config_Descriptor>
- (http://www.alteraforum.com/forum/) <bmAttributes>
<RemoteWakeupEnabled>false</RemoteWakeupEnabled>
<SelfPowered>true</SelfPowered>
<BusPowered>false</BusPowered>
</bmAttributes>
<IOpullDown>true</IOpullDown>
<MaxPower>150</MaxPower>
</USB_Config_Descriptor>
- (http://www.alteraforum.com/forum/) <USB_String_Descriptors>
<Manufacturer>Altera</Manufacturer>
<Product_Description>USB-Blaster</Product_Description>
<SerialNumber_Enabled>true</SerialNumber_Enabled>
<SerialNumber>BLASTR01</SerialNumber>
<SerialNumberPrefix>BL</SerialNumberPrefix>
</USB_String_Descriptors>
</FT_EEPROM>
    --- Quote Start ---
    My EEPROM is blank device.
    Chip Type: FT232/245BM
    Vendor ID: 0x0403
    Product ID: 0x6001
    Product Desc: USB <-> Serial Converter
    Manufacturer Desc: FTDI
    Location ID: 0x341
    EEPROM Type: 93C46 EEPROM
    BLANK DEVICE
    --- Quote End ---
    You should be able to use FT245B_BLASTR01_xml.txt in the post above. Download the file, change the filename to FT245B_BLASTR01.xml, then in FT_PROG select the FT245 device, right click, apply template, and select the XML file. Then program it. Unplug and plug the device back in, and it should get detected as a USB-Blaster.
    Let me know if that works.
    Cheers,
    Dave
    When I programm the device, operation failed with message "The current drawn from the USB port must be in the range 0 to 500 mAmps."
