AEsqu
Contributor
7 years agoUSB Blaster disapears from the hardware setup of the quartus prime programmer when I connect a com port with the teraterm using an FTDI usb to I2C adapter.
USB Blaster disapears from the hardware setup (no hardware) of the quartus prime programmer when I connect a com port with the teraterm using an FTDI usb to I2C adapter. The only way to see the usb ...
AEsqu
Contributor
7 years agoOf course I tried, there is no usb hw present in the list when my terminal is open with the com port (that was my original issue).
I tested with quartus 18.1, same issue.
To work around the problem, I will program my FPGA using another pc.
ShafiqY_Intel
7 years agoHi AEsqu,
Let us know the results when you program it using another pc. Thanks
