15 years agoURGENT: Peripheral to Memory DMA Transaction
Hello, may I know how to transfer data from peripheral to memory using DMA? It is quite confusing from memory-to-memory transfer. please help! thanks!
15 years ago --- Quote Start --- Does you adder give a signal when it's done processing? That should go then to outgoing_fifo write signal. --- Quote End --- No, once it adds the two number, i will wait for address = '1', then it will send the result out. --- Quote Start --- Use the address signals for the incoming fifo write and outgoing fifo read. You'll need to <AND> it with the avalon write signal, so you don't write data into the incoming fifo when accidentally reading from address 0. (Same goes for outgoing fifo.) --- Quote End --- this part is a bit confusing. the avalon write signal is the external signal? when address = 0, the data will be written into adder, when address = 1, the result will be sent out from adder. besides, can FIFO write and read at the same, which means, wrreq and rdreq both is high at the same time?
