Donna's avatar
Donna
5 years ago
Urgent: INTEL - Component Life Cycle Survey - July '21
Dear Supplier,
Good day. Please CONFIRM if your products LIFE CYCLE are still VALID or ACTIVE and provide life cycle for those parts with NO DATA (if there's any) in Column F.
If it will be easier for you, you may answer our survey using the family, series and/or package type of the components you supply to us.
NOTE:
The purpose of the Component Life Cycle (CLC) Survey is to understand the remaining life of the component that will be used by Artesyn primarily for:
1. BOM Design during New Product development.
2. Making alternate proposals for multi sourcing in the BOM during New Product Introduction (NPI) and mass production stage to improve the supply chain of the product.
3. Emphasis must be given on the accuracy of the remaining years to EOL for each component such that an authorized and competent representative must handle the response to the survey to avoid possible repercussions due to erroneous data.
4. For any component going End-of-Life (EOL), the supplier shall issue a Product Termination Notice/Process Change Notification (PTN/PCN) to the PCN coordinator ([email protected]) 6 months prior the EOL effectivity date.
5. We would consider to use the current data in our system should you have no concerns/feedback raised after 30 days with Remarks Non Responsive Supplier.
  • We do not receive any response from you to the previous answer that I have provided. This thread will be transitioned to community support. If you have a new question, feel free to open a new thread to get the support from Intel experts. Otherwise, the community users will continue to help you on this thread. Thank you
  • Hi,
    Generally, we are not helping the customer to fill in the information based on customer request format if those require information can be obtain from our website.
    For your information, Max V device family is still active and available. Anyhow, the life cycle is depending on its order volume.
    You can subscribe to our customer notification mailing list at below link so that you can be notified when an Altera(now Intel) device is going to be discontinued.
    https://www.intel.com/content/www/us/en/programmable/support/support-resources/knowledge-base/solutions/rd04252012_977.html
    Aiman
    • Donna's avatar
      Donna
      So these 3 parts mentioned are still ACTIVE and valid to use, is that right? Thanks
      5M160ZE64C5N
      5M40ZE64C5N
      5M80ZE64C5N
      • Donna's avatar
        Donna
        Can you please confirm if these 3 parts are still ACTIVE and valid to use? Can you still produce these parts. Need your confirmation asap. Thanks
        5M160ZE64C5N
        5M40ZE64C5N
        5M80ZE64C5N
