17 years agoUrgent help, Quartus error
Dear friends,
I started to work with Quartus II recentlly and my current project went very well until I discovered "Timing Optimization Advisor" :eek: . I followed its reccomendations about "Perform Multicorner Analysis" or something I can't remember exactlly because now dissapeared (I clicked some button that tells me to correct) and since then, Quartus stops at Timing anaysis with this error: Error: Cannot find minimum timing model for device epm3064a I reset to default all settings but still error. What should I do pls? Thanks in advance,2 Replies
I use 9.0 SP2 downloaded few days ago. Seems some setting was set (--fast) but I was not able to undone or I couldn't find in Settings menu. I had to make a new project and include my old schematic file, so now is working again.
I have some little problems with Quartus way of organize things (menus, etc.). For example I noticed there are "Tools" also inserted in other menus than Tools, etc. I have to get use to. Best regards, Richard, - Altera_Forum
--- Quote Start --- Dear friends, I started to work with Quartus II recentlly and my current project went very well until I discovered "Timing Optimization Advisor" :eek: . I followed its reccomendations about "Perform Multicorner Analysis" or something I can't remember exactlly because now dissapeared (I clicked some button that tells me to correct) and since then, Quartus stops at Timing anaysis with this error: Error: Cannot find minimum timing model for device epm3064a I reset to default all settings but still error. What should I do pls? Thanks in advance, --- Quote End --- Hi, which Quartus version did you use ? I check the version 9.0 SP2 and I found that fast timing is not supported for EPM3064a. How did you make the setting ? Kind regards GPK
