17 years agoUrgent help, Quartus error
Dear friends, I started to work with Quartus II recentlly and my current project went very well until I discovered "Timing Optimization Advisor" :eek: . I followed its reccomendations about "...
17 years ago --- Quote Start --- Dear friends, I started to work with Quartus II recentlly and my current project went very well until I discovered "Timing Optimization Advisor" :eek: . I followed its reccomendations about "Perform Multicorner Analysis" or something I can't remember exactlly because now dissapeared (I clicked some button that tells me to correct) and since then, Quartus stops at Timing anaysis with this error: Error: Cannot find minimum timing model for device epm3064a I reset to default all settings but still error. What should I do pls? Thanks in advance, --- Quote End --- Hi, which Quartus version did you use ? I check the version 9.0 SP2 and I found that fast timing is not supported for EPM3064a. How did you make the setting ? Kind regards GPK
