14 years agoUpdating EPCS with new configuration via FPGA
Hi all, Currently I am trying to develop a way of updating the EPCS memory connected to a stratix II device dynamically via the FPGA. The idea is that an external processor will send the configura...
14 years ago --- Quote Start --- Review ALTASMI_PARALLEL MegaFunction. --- Quote End --- Thanks for the reply. I have been studying this megafunction but either I am not understanding properly its function or there is insufficient information. Nowhere in the user guide does it talk about how to send a configuration file to the EPCS, just about how to write a byte or a page. It´s not entierly clear that the intended function of this megafunction is to update the design configuration as I want to to do. Also on page 2 of the user guide there is a warning which says "Do not access the configuration memory in the EPCS device. Doing so risks corrupting the configuration bits." I assume this refers to teh actual binary being stored. I am a little confused as to why this is not explained in further detail in the user guide. Is it that unusual to want to do something like this? --- Quote Start --- We use the SFL stuff (AN370) here in the company. You need to check AN425 on how to implement the "JAM player" into your processor. I've asked our software guy; he said it's quite easy . --- Quote End --- Thanks Michaels. Unfortunately I don´t have a processor in the design and was hoping to avoid using a NIOS, as this is a last minute request from someone to a design more or less finalized. Many thanks for the help so far.
