14 years agoUnused CPLD Pins
I have two CPLDs on my PCB that connect to a common SPI bus. In order to keep things simple I'm trying to talk to only one of the chips at first but I'm having some trouble with the voltages which le...
14 years agoJust to update you, Dave. The problem was indeed that the unused pins were set to "as outputs driving ground". When I changed it to "tristate inputs with weak pull up" the voltage went back to 3.3V.
I have the data transferring now and I've also modified the code to use the 8 MHz global clock instead of relying on SCK, as it was before in my old design.begin
sync1: process(CLK)
variable resync: std_logic_vector(1 to 3);
begin
if rising_edge(CLK) then
rise <= resync(2) and not resync(3);
fall <= resync(3) and not resync(2);
resync := SCK & resync(1 to 2);
end if;
end process;
process (CLK,nCS)
begin
if (nCS='1') then
tmp <= PI;
elsif rising_edge(CLK) then
if(fall = '1') then
tmp <= tmp(PI'high -1 downto PI'low) & '0';
end if;
end if;
end process;
SO <= tmp(PI'high) when nCS = '0' else 'Z'; Sorry about the non-indentation. The forum seems to be messing up my tabs.
