14 years agoUnused CPLD Pins
I have two CPLDs on my PCB that connect to a common SPI bus. In order to keep things simple I'm trying to talk to only one of the chips at first but I'm having some trouble with the voltages which le...
14 years ago --- Quote Start --- Thank you. And just to be sure - when an external signal overrides this weak pull up it will not damage the CPLD as the pins will be in tri-state? --- Quote End --- That is correct. Cheers, Dave
