18 years agoAre you getting this error consistently or the error code gets changed in every attempt made in using the JTAG port? There may be issue with poor electrical connectivity. Are you using Byte Blaster II or USB Blaster? If you are using a Byte Blaster II cable, give USB Blaster a try or vice versa.
