14 years agounderstanding library "Work"
I am getting an error I am not sure how to approach: Error (10430): VHDL Primary Unit Declaration error at pulse_across_clock_domains.vhd(36): primary unit "pulse_across_clock_domains" already...
14 years agoyou could:
1. compile portions of the designs in individual projects and export the post-map .qxp, then import it into the top level project. i put a script on alterawiki.com to do just this because its a common problem when using DSP Builder 2. use .qip files to add all of your sources to the project, adding the -library <lib_name> flag. this is how Altera is avoiding module name clashes in things like memory controllers
