14 years agoUnderstanding Clocks for Arria II
I am trying to understand the clock signal of the Arria II. What I want to know is: 1. Is there one main clock input signal for the entire chip? 2. Or is there up to 8 main PLL inputs that dr...
14 years agoThere's no minimum clock frequency for the FPGA; only for the PLLs (and transceivers).
As for maximum clock frequency, it's a bit more complicated. I think the FPGA input clock pins will accept clocks up to 500 MHz, but only with differential I/O standards. With single ended (ie, LVCMOS), the maximum frequency will be lower. And the maximum frequency at which your design will be able to operate will depend on your design and on the FPGA's speed grade. What you need to do is to synthesize your design (with I/O assignments) and see the timing report. If you don't have a prototype of your design, try to create a simple mock up.
