10 years agounderstanding avalon slave <-> master transfers
Hello, I am trying to understand how avalon slave <-> master read and writes are working, I have seen the master and slave templates and several manuals and sheets and posts about that but I am...
10 years ago --- Quote Start --- Based on the above I put together a simple two way set associative instruction cache with 4Kb internal memory and it works in the simulator with a simple test toplevel entity but now I need to check how I can simulate this after I set it up in a qsys system. --- Quote End --- After you get this packaged into a Qsys component with a _hw.tcl file, what you want to do is to get a simulation going with the Avalon BFM's Search on here for "BFM" and you'll find threads and examples. https://www.altera.com/support/support-resources/design-examples/design-software/simulation/exm-avalon-verification-ip.html
