12 years agoUnconstrained output ports
Hello sir, I want to place a DDR SDRAM (MT46V64M8 – 16 Meg x 8 x 4 banks) with cyclone IV E (ep4ce55f23i7) device. On doing the Early Pin Planning of DDR with this device I am getting...
12 years agoSimple Problem: Your Output-Ports are unconstrained (somehow obvious).
Generate a SDC-File containing the constraints like "set_max_skew" and so on to tell the fitter how to handle the signals and to tell TimeQuest how to analyze them. To ignore this warning is possible but may end in an not working design because of massive skew between the parallel signals. This is why you should tell quartus which signals belong to the bus and how much skew, delay and so on is acceptable. The fitter then tries to keep the signals together.
