18 years agounable to scan device chain. cann't scan jtag chain
Hi, I am using Nios II Embedded Evaluation Kit (Cyclone III - EP3C25F324C6NES). Though it is having direct programming capability through the Usb cable. I like to test the Program...
18 years ago --- Quote Start --- Hi, JP1 is closed ... on the board ... Should I have to remove it ??? Thanks, Srinath., --- Quote End --- Hi Srinath, JP1 closed should be ok. Is JP2 also closed ? What signal could you observe on JP1, in case you try to scan the chain?
