18 years agounable to scan device chain. cann't scan jtag chain
Hi, I am using Nios II Embedded Evaluation Kit (Cyclone III - EP3C25F324C6NES). Though it is having direct programming capability through the Usb cable. I like to test the Program...
18 years ago --- Quote Start --- Hi, I have the Cyclone III FPGA Starter Board Reference Manula (Dated : - October 2007) I think this is the new manula available. In that manula it was mentioned to add the Jumper to JP8 to work eith JTAG, Even though I added the Jumper even then the same error continues.... Please see below for the specifoed point from the document ... " JP8 : Adding the shunt enables configuration of the Cyclone III device using the JTAG header and an external USB-Blaster. When the shunt is not in place, the embedded USB-Blaster circuitry must be used to configure the Cyclone III device. (The board ships without the JTAG header populated.) " Now what to do ??? Thanks, Srinath. --- Quote End --- Did you try the embedded USB-Blaster ? In my understanding you have only to connect your PC with the USB port on the board. Is that working ? At least this should work, because this is according to the manual the default board configuration.
