UART-hyperterminal interface in verilog code
Hello all,
I am doing my final year BE project on altera's ESDK kit. I want to interface my PC with that kit via RS-232-Hyperteminal. I have write code for UART-RX in verilog,load that code in kit,connect RS-232 bet PC & kit but not geting any o/p on kit. so plz can you help me out in this matter. here i m attching that verilog code for your reference. Regards, sagar9 Replies
--- Quote Start --- I am stil having the same problem...... I cannot connect UART to my HyperTerminal :( . I am trying to use JTAG-to-Avalon Memory Tutorial and see what happens :( Thanks --- Quote End --- Try this code /* * uart.c * * Created on: Feb 8, 2013 * Author: krishnakumar */ # include <stdio.h> # include <unistd.h> # include "system.h" # include "alt_types.h" # include "sys/alt_stdio.h" # include "pheripheral_comm.h" # include "string.h" # include "altera_avalon_pio_regs.h" # include "altera_avalon_uart.h" # include "altera_avalon_uart_regs.h" int ReadAddData(int); int uart_1(void) { int Address = 0; int Data = 0; alt_putstr("Enter Address : "); Address = ReadAddData(5); if((Address < (int)PIO_0_BASE) || (Address > (int)PIO_0_BASE+0xF))//|| (Address >= PIO_0_BASE-0x50-0x1)) { alt_putstr("Wrong Address for LED\n"); return 0; } WRITE_CHAR_TO_HYPERTERMINAL('\n'); alt_putstr("Enter Data : "); Data = ReadAddData(2); WRITE_CHAR_TO_HYPERTERMINAL('\n'); IOWR_ALTERA_AVALON_PIO_DATA(Address, Data); return 0 ; } - Altera_Forum
I cannot connect UART to my HyperTerminal :( . I am trying to use JTAG-to-Avalon Memory Tutorial and see what happens :( Thanks - Altera_Forum
Hi All,
--- Quote Start --- Try using putty instead of hyperterminal. --- Quote End --- I have made a nice connection between PuTTY and RS232. It is fine, However, I need to transfer an entier file. How can I do this with PuTTY? Please help - Altera_Forum
hi,can i know did u success to developing the interface between rs232 and pc?if yes,can u upload the codes for reference?thanx...
hey... were u able to do serial communication using rs232 succesfully... please can u tell me the exact steps... nd send the verilog code required... please please il b very greatful
u cn mail me as well ahuja.tapsi at gmail - Altera_Forum
I think you are trying to do too much at once. Start out with a simple rx/tx uart (rx first, then tx) and then add features to it. We don't even know if you are using an RS232 voltage level convertor properly. Also make sure you write a good testbench and build it as you add functionality. This is the only way to tackle designs, especially one like this which can be broken down easily into multiple independent functions. Look up the spiral approach to software development. set up another PC if you can and just have that PC talk to and fro with hyperterminal by switching tx/rx signals . In this way you can systematically build your application up.
--- Quote Start --- hi... me too have the same problem... can u please help me with the program if u get a solution. thank u. my email id is [email protected] thank u. --- Quote End --- 1) check the pin assignments carefully. 2) check the baud rates - Altera_Forum
