Shoval
2 years agoUART 16550 compatible Linux device
Hello all, In my Quartus project I connected a UART 16550 compatible soft IP, and it is visible in the .sopcinfo generated. Later I build a .dtsi and a .dtb files using yocto angsrom, in the .dtsi ...
aikeu
2 years agoHi Shoval,
I missed out the part which referring to the 16550 ip when browsing through the nodes.
May I know the exact address which the 16550 soft ip is pointing in the qsys design?
From the below, I am seeing the address is directly pointing to 0x00000000 :
a_16550_uart_0: serial@0x000000000
Aik Eu
- Shoval2 years ago
The address of the IP is 0xc0000000, its base address is 0xc0000000 under "hps_0_bridges" with an addresss offset of 0x00000000.
as you can see from the .dtsi file below:
hps_0_bridges: bridge@0xc0000000 {compatible = "altr,bridge-18.1", "simple-bus";reg = <0xc0000000 0x20000000>,<0xff200000 0x00200000>;reg-names = "axi_h2f", "axi_h2f_lw";#address-cells = <2>;#size-cells = <1>;ranges = <0x00000000 0x00000000 0xc0000000 0x00000200>,<0x00000001 0x00020000 0xff220000 0x00000008>,<0x00000001 0x00020010 0xff220010 0x00000008>;a_16550_uart_0: serial@0x000000000 {compatible = "altr,altera_16550_uart-18.1", "altr,16550-FIFO128", "ns16550a";reg = <0x00000000 0x00000000 0x00000200>;interrupt-parent = <&hps_0_arm_gic_0>;interrupts = <0 40 4>;clock-frequency = <100000000>; /* embeddedsw.dts.params.clock-frequency type NUMBER */fifo-size = <128>; /* embeddedsw.dts.params.fifo-size type NUMBER */reg-io-width = <4>; /* embeddedsw.dts.params.reg-io-width type NUMBER */reg-shift = <2>; /* embeddedsw.dts.params.reg-shift type NUMBER */}; //end serial@0x000000000 (a_16550_uart_0)######
Attached is the .dtsi file, under line 99 is the hps_0_bridge node instance and under line 110 is the 16550 UART node instance.
(suffix changed to .txt for upload purposes)
