10 years ago[U-boot] bridge_enable_handoff failed to run
Hi All, When I run the bridge_enable_handoff command (run bridge_enable_handoff), I receive the following:# # Starting application at 0x3FF79720 ...# # Application terminated, rc = 0x0 ...
10 years agoUnfortunately I'm not an Embedded Engineer, just a FPGA Engineer... Will look through the referenced by you docs, thank you!
