10 years ago[U-boot] bridge_enable_handoff failed to run
Hi All, When I run the bridge_enable_handoff command (run bridge_enable_handoff), I receive the following:# # Starting application at 0x3FF79720 ...# # Application terminated, rc = 0x0 ...
10 years ago1) "need to build a new preloader" - what should the preloader include?
2) "set the axibridge_handoff by hand before freeing the bridges" - how should I do so? what commands to run? 3) while building the preloader, is it possible to add more u-boot commands (like unix-like 'grep', 'which',etc.)?
