10 years ago[U-boot] bridge_enable_handoff failed to run
Hi All, When I run the bridge_enable_handoff command (run bridge_enable_handoff), I receive the following:# # Starting application at 0x3FF79720 ...# # Application terminated, rc = 0x0 ...
10 years agoeverythings seems to be okay.
If you are unable to access the bridge (lwhps2fpga) you may need to build a new preloader or set the axibridge_handoff by hand before freeing the bridges, but after programming the fpga.
