15 years ago
type of identifier "clock" does not agree
Hi everyone,
I have a problem due to the type of identifier "clock" as I declare as a bit type. Below is my short code:
Package my_main_data is
Type main_vector is array (7 downto 0) of integer;
End my_main_data;
LIBRARY ieee;
USE ieee.ALL;
Use work.my_main_data.all;
Use work.my_data_types.all;
ENTITY case IS
PORT (
clock : IN bit;
Ip : IN main_vector;
Op : OUT main_vector
END case;
ARCHITECTURE case OF case IS
COMPONENT cone
PORT (
I: IN vector;
clk: IN bit;
O: OUT vector
END COMPONENT;
SIGNAL out_r1, out_r2: vector;
SIGNAL clk : bit;
BEGIN
R1: cone
PORT MAP (Ip(0), clock, out_r1(0);
PORT MAP (Ip(1), clock, out_r2(0);
End case;
This error occur when I compile the code:
Error (10476): VHDL error at haar.vhd(62): type of identifier "clock" does not agree with its usage as "integer" type
Can anyone tell me where is my mistake..http://www.edaboard.com/images/smilies/icon_sad.gif Many thanks
    I'm not aware of a legal VHDL syntax with multiple port maps in a single component instantiation.
    I dont beleive this is the same code you're trying to compile.
    And where is the definition of the "vector" type?
