mac23
2 years agoTwo MAX10 FPGAs, one sends packets and the other doesn't.
Hello, I have two MAX10 FPGAs1050DAF484C6GES, I run the same program and execute the same Tcl script to run the ethernet program found here Intel® MAX® 10 FPGA – Single-Port Triple Speed Ethernet an...
aaronkwak
2 years agoI will answer in passing.
I think you know, but if you just look at the content and explain it,
The FPGA sends packets, but the other side does not transmit or is not connected.
first
0x7c aOctetsReceivedOK 0
In this case, the problems are widespread.
RX link defective (physical)
Interprotocol Differences
Destination address issues (MAC Address, etc.?)
Please try connecting to a board (equipment) that is connected normally.
It seems like we can find out if the problem is with that port.
I hope it helps you with your work.
First, you need to check whether the physical channel problem is normal.
