hsyn
2 years agotroubleshoot for 5CSEBA4U23I7N (cyclone V fpga processor)
Hello, I am trying to troubleshoot a pcb with a 5CSEBA4U23I7N cyclone V fpga processor. The resistance value I measured between 3V3 and GND for the intact pcb is around 380ohm. One of the PC...
cfkd
2 years agoHi,
Thank you for your question.
As the device is not mounted, you cannot test with some logic.
Any tampering with the device not as per the recommendation can void the warranty.
If you would like to test without the power, you will be required to send for RMA process by contacting local Sales for filing IPS case to start RMA.
Chee
