15 years agoTrouble with Cyclone IV FIFO
Hello, i use modelsim6.5, i have design with two type of fifos. If i try use simulation there is this error:
# ** Fatal: (vsim-3420) Array lengths do not match. Left is 8 (7 downto 0). Right is 32 (31 downto 0).# Time: 0 ns Iteration: 0 Process: /tb_toplevel/top_testbench/merici_frontend/gen_fifos__1/fifos/line__47318 File: C:/modeltech_6.5b/win32/../altera/vhdl/src/altera_mf/altera_mf.vhd# Fatal error in Architecture behavior at C:/modeltech_6.5b/win32/../altera/vhdl/src/altera_mf/altera_mf.vhd line 47320 Declaration of fifo is: dcfifo_mixed_widths generic map ( intended_device_family => "Cyclone IV E", lpm_hint => "MAXIMIZE_SPEED=5,", lpm_numwords => 256, lpm_showahead => "OFF", lpm_type => "dcfifo", lpm_width => 32, lpm_widthu => 8, lpm_widthu_r => 10, lpm_width_r => DATA_WIDTH, overflow_checking => "ON", rdsync_delaypipe => 3, underflow_checking => "ON", use_eab => "ON", write_aclr_synch => "ON", wrsync_delaypipe => 3) port map ( rdfull => rd_fifo_full(i), wrclk => CLK, rdempty => rd_fifo_empty(i), rdreq => fifo_rd_en(i), aclr => reset, wrfull => wr_fifo_full(i), wrempty => wr_fifo_empty(i), rdclk => CLK, q => fifo_output(i), wrreq => pulse_from_sensor(i), data => cnt_to_fifo(i)); width is 32b for cnt_to_fifo and 8b for fifo_output. I dont know waht is wrong, because width is the same. If i try use it in the Cyclone II (i change device type) simulation is working with these settings. Any suggestions? Thank you, VaclavNo RepliesBe the first to reply
