10 years agotransmit raw file to a flash device connected to altera device
provided that I have a raw data file describing exactly how data must fit into a flash device connected to an altera device, is there an altera-approved method to transfer this file into flash device...
10 years agoHi,
the FPGA programming devices (EPCS, ECPQ) can be programmed in two basic ways:- you generate a .jic-file, connect to the FPGA via JTAG (USB-Blaster), and program the file into the flash through the FPGA
- you generate a .rpd-file, and program it into the flash using an SPI master
