17 years agoTransmit 2 bits of 1MHz (modulation)
Hello, Y have one signal of 2 bits and with one bandwidth about 1MHz and I need send this bits using one fiber optic (FO) cable. Transmit one signal over fiber optic is easy because I ...
17 years agoHi,
PWM is much easier than other types of modulation. As you said you will map the 2 bit input to the 3 voltage levels using a simple mux. I assume your input clk is 100MHz then you can produce 25MHz at 25%, 50% and 75% duty cycle using simple counter. Then you switch out the generated clocks as per incoming levels. I am not that sure about demodulation plan and would like to learn from your work. I assume it will be straight forward if the Tx/Rx clocks are synchronised I suggest the following process to generate the duty cycles(code not tested) signal count : integer range 0 to 3 := 0; ------ process(reset,clkin) -- 100MHz clkin begin if(reset = '1')then count <= 0; clkout <= '0'; clk1 <= '0'; -- 25MHz, 25% duty clk2 <= '0'; -- 25MHz, 50% duty clk3 <= '0'; -- 25MHz, 75% duty elsif(rising_edge(clkin))then count <= count + 1; case count is when 0 => clk1 <= '1'; clk2 <= '1'; clk3 <= '1'; when 1 => clk1 <= '0'; clk2 <= '1'; clk3 <= '1'; when 2 => clk1 <= '0'; clk2 <= '0'; clk3 <= '1'; when 3 => clk1 <= '0'; clk2 <= '0'; clk3 <= '0'; when others => null; end case; case input_level is when "00" => clkout <= clk1; when "01" => clkout <= clk2; when "10" => clkout <= clk3; when others => null; end case; end if; end process;
