17 years agoTransmit 2 bits of 1MHz (modulation)
Hello, Y have one signal of 2 bits and with one bandwidth about 1MHz and I need send this bits using one fiber optic (FO) cable. Transmit one signal over fiber optic is easy because I ...
17 years agoHi KAZ, thanks for your answer.
For my design I have 2 binari TTL inputs (that correspond to 3 levels of voltage) and they can change with a frequency of 1MHz. I can modulate one signal using PWM to transmit the 3 levels? For example: - Frequency of the PWM = 25MHz - First level: Duty cycle at 25% - Second level: Duty cycle at 50% - Third level: Duty cycle at 75% The comunication is always digital. Is easy this modulation/demodulation using one low cost MAX II ? Do you recommend using VHDL or graphic language? Thanks!
