10 years agoTransfer data from HPS DDR3 to FPGA SDRAM and back using DMA
Hello, For several weeks, I tried to send data between memories but without any success. I'm using DE1-SoC board with Linaro Linux on SD card. Firstly I would like to run application which is on A...
10 years agoI read some topics about msgdma and I made qsys configuration. I'm not sure if I did it well. Can you check if it is correct?
If it is ok, how to send data from hps to sdram? In topic http://www.alteraforum.com/forum/showthread.php?t=50103 there is a piece of code but not all. It is kind of black magic for me :( Looking on this code... MAP_PIO_SIZE will be 0x001? The same code i must write to the descriptor? What with response? I generate hps_0.h and there are only csr and descriptor. Sorry for so many questions but its my first hps-fpga project and i am not good at it yet.
