10 years agoTransfer data from HPS DDR3 to FPGA SDRAM and back using DMA
Hello, For several weeks, I tried to send data between memories but without any success. I'm using DE1-SoC board with Linaro Linux on SD card. Firstly I would like to run application which is on A...
10 years ago --- Quote Start --- Hello, For several weeks, I tried to send data between memories but without any success. I'm using DE1-SoC board with Linaro Linux on SD card. Firstly I would like to run application which is on Altera site (https://www.altera.com/support/support-resources/design-examples/soc.html - HPS DMA) but I want to send data to sdram instead to On-chip-memory. I was looking for some another examples but there are nothing in the internet. Could someone help me with this? How to connect sdram and dma controller in Qsys? Whether the application code will be the same? Maybe someone has a working example, which would like to share? --- Quote End --- search for "msgdma" on this forum. There are two threads that go over this process quite well. I have a working system now, and several others on the forum do as well. The examples are posted in some of the other threads. Happy to help out if you need any other advice.
