11 years agoTransceiver placement issue
Is there any guru who can help to place more than one transceivers in one GXB block? I tried to design two 2 channel transceivers in one GXB block that has 4 channels. Quartus II fitter always fai...
11 years agoI believe you are creating two ALTGX instances and fit them into one XCVR bank. You could share a single reconfig instance between the two ALTGX instances to see if can pass Fitter. Note that the the ALTGX instances still operate independent even though they are sharing one reconfig instance.
