Transceiver Asynchronous SSC RX
As I understand it, you have some inquiries related to FPGA which has XCVR supporting the asynchronous SSC modulation. Sorry for the inconvenience. Based on my understanding, I am not aware of any of our FPGA transceivers which could support the asynchronous SSC modulation by itself. The max ppm threshold support by a CDR is generally +-1000ppm and the SATA like modulation would easily exceed the threshold and cause CDR losing lock.
However, as I understand it, our design partner has SATA IP which should be able to handle the asynchronous SSC. You may try to contact our design partner if you would like to know more about their IP at https://www.intel.com/content/www/us/en/programmable/solutions/partners/partner-profile/designgateway-co---ltd-/ip/sata-ip-core.html. Note that there will be charges for their IP.
Chee Pin
