13 years agoTransaction Reordeingr Feature in Altera's PCI Express Application Interface/DMA
I am using the Altera's free application interface /DMA that comes with PCI Express core. I want to know whether this DMA has completion reordering feature or not? I used my hardware setup with jungo windriver. I am transferring 8Gb data from PC to DDR3 memory(attached on my custom board) using DMA. On one PC I found that the received data has some ordering issue quite frequently. But the strange part is that I am not getting this problem on another PC even after several transfers. Since 8Gb data is quite big I should have problem on the other PC as well. What else can be the issue? Thanks Ali Umair1 Reply
I'd guess that the fpga generates the TLP in address order, however the PC end might generate terminations in a different order from which the requests are generated.
Even snooping the cpu data cache could make a difference.
